Hi All,
How to drive signal asynchronously in system verilog class.(just like “assign” construct used in Verilog)…?
Regards,
Manoj
Hi All,
Regards,
Manoj
“assign” doesn’t mean asynchronous drive, it means continuous drive. You can’t do it from a class, you can only do procedural drives.
In reply to manoj_k86:
You need to be more explicit about the behavior you are looking for. An assign statement is just a process that waits for a change on the RHS to make an assignment to the LHS. You can create a process from within a method of a class to do something similar, but process has to call that method. It would really help to know what you are trying to achieve.
In my test-bench, I have to drive signal on DUT port synchronously or asynchronously depends on DUT mode.The clock used in drive signal is provided by DUT.So that,In some cases this DUT clock is turned-off and I have to drive signal asynchronous(continuous without any clock reference).
Looking for your response on same.
How about showing a self-contained example of how you would do this in a SystemVerilog/Verilog testbench without classes? Then we can show you how to do the same thing with a class based testbench.
Have a look following example :
//DUT mode change by test-bench according requirement
module test;
bit tb_clk;
bit dut_clk;
bit dut_mode;
bit [7:0] data_in,asyn_data_in,syn_data_in;
bit clk_on;
assign data_in = clk_on ? syn_data_in : asyn_data_in;
//Synchronous
always @(posedge dut_clk)
syn_data_in = 8’hff; //syn_data_in drive logic
//Asynchronous
assign asyn_data_in = 8’h00;//asyn_data_in drive logic
always @(posedge tb_clk)
if(dut_mode)
clk_on = 1’b1;
clk_on = 1’b0;
initial
#10;
dut_mode = 1’b1;
#50;
dut_mode = 1’b0;
#50;
$stop;
initial
tb_clk = 1’b0;
forever #5 tb_clk = ~tb_clk;
dut tb_dut(
.clk_in(tb_clk),
.dut_mode(dut_mode),
.data_in(data_in),
.clk_out(dut_clk)
endmodule : test
//DUT
//requirement
//“data_in” port drive with reference of “clk_out” when available otherwise drive continuous.
module dut(
input clk_in,
input dut_mode,
input [7:0] data_in,
output reg clk_out
always @(posedge clk_in)
if(dut_mode)
//output clock generation logic
//disable output clock
// data_in related logic
How to implement above verilog test-bench logic in system verilog class based test-bench…?
Hi Manoj,
How about the following code?
class test;
bit tb_clk;
bit dut_clk;
bit dut_mode;
bit clk_on;
function new ();
asyn_data_in = 8'h00;
task run
drive_syn_data_in;
drive_clk_on;
drive_data_in;
join_none
task drive_syn_data_in;
forever begin
@(posedge dut_clk);
syn_data_in = 8'hff;
task drive_clk_on;
forever begin
@(posedge tb_clk);
if(dut_mode)
clk_on = 1'b1;
clk_on = 1'b0;
task drive_data_in;
forever begin
if (clk_on)
data_in = syn_data_in;
data_in = asyn_data_in;
#1;
