how can we write a assumptions for the following scenario in SVA
signal A,B
if signal A is high then it should be remain high until B becomes 1
Thanks in advance…
Regards,
Siva.
signal A,B
Thanks in advance…
Regards,
Siva.
In reply to sivareddy437:
assume property (@(posedge clk) $rose(A) |-> A until B);
Thanks Dave,
i used in following way,
assume property (@(posedge clk) $rose(A) |-> A throughout B[->1]);
Thanks Dave,
It’s the same as
assume property (@(posedge clk) $rose(A) |-> A until_with B);
