Assign a range of number in unpacket array
Hi : I am not sure how to put a range of data inside of unpacked array, or q[$], dynamic array.
for example int array = '{ 'h1, 'h6, 'h20:'h2f};
i will get error on 'h20:'h2f
thanks
There is no syntax to get a range of numbers in an assignment directly, but you can create a function to do it for you.
   int A1[], Q1[$],F1[10];
   typedef int DA_t[];
   function automatic DA_t range(int first, last);
      int      index;
      if (first < last)
	   range = new [last-first+1];
	   for(int i=first;i<last+1;i++)
	     range[index++] = (i);
	   range = new [first-last+1];
	   for(int i=first;i>last-1;i--)
   endfunction : range
     A1 = {32'h1, 32'h6, range('h20,'h2f)};
     Q1 = {'h1, 'h6, range(30,25),range(5,1) };
     F1 = {'h1, 'h6, range('h20,'h27)};
      $display("%p",A1);
      $display("%p",Q1);
      $display("%p",F1);
endmodule : top
Thanks Dave.
It helps. but I am thinking if it makes sense to you if Systemverilog LRM can support it in next release. I think it is a fundamental but it is very useful. In my case, i have a router fabric, like
my_port = '{ x }
my_other_ports = '{ … }
without this feature, i have to either use the methode you provided or manully write it.
just my opinion.
thanks
In reply to aming:
There already is an enhancement request, but it will miss the next revision, due out by the end of the year.
Thanks Dave. unfortunatelly, it does not get compiled in VCS.
