Assertions for clock frequency
Hi folks,
I have implemented the assertion to check the clock frequency for 400Mhz, but at some point the clk frequency will change from 400mhz to 200mhz by configuring the clk_divider. The frequency is changing with 10 clk cycles delay where my assertions are getting failed. how to avoid these 10 clk cycles delay in my assertions.
Thank you,
Vinay Kumar
In reply to Vickyvinayk:
Use the assertion control. You’ll need support logic to use those controls at the appropriate timings.
$assertcontrol ( control_type [ , [ assertion_type ] [ , [ directive_type ]
                         [ , [ levels ]  [ , list_of_scopes_or_assertions ] ] ] ] ) ;
$assertoff stops the checking of all specified assertions until a subsequent $asserton.   An assertion that is already executing, including execution of the pass or fail statement, is not affected.  It is equivalent to:
$assertcontrol(4, 15, 7, levels [,list])
$asserton  re-enables  the  execution of  all  specified assertions.    It  is  equivalent  to:
$assertcontrol(3,  15,  7,  levels  [,list])
// from my book
/* Assert control  Rule:  The $assertcontrol provides finer granularity in how and which types of assertions are controlled. The syntax is repeated below:  */
$assertcontrol ( control_type [ , [ assertion_type ] [ , [ directive_type ]                           [ , [ levels ]  [ , list_of_scopes_or_assertions ] ] ] ] ) ;
[1] The arguments for the $assertcontrol system task are described below:
— control_type: This argument controls the effect of the $assertcontrol system task.  This argument shall be an integer expression.  Section 4.2.4.1.1 describes the valid values of this argument.
— assertion_type: This argument selects the assertion types that are affected by the $assertcontrol system task.  This argument shall be an integer expression.  Section 4.2.4.1.2 describes the valid values for this argument.  If assertion_type is not specified, then it defaults to all types of assertions and expect statements (i.e., Concurrent, Simple Immediate, Observed-Deferred Immediate,  Final Deferred Immediate, and expect).
— directive_type: This argument selects the directive types (i.e., assert, cover, assume) that are affected by the $assertcontrol system task. This argument shall be an integer expression.  Section 4.1.4.1.3 describes the valid values for this argument.  If directive_type is not specified, then it defaults to all types of directives.  — levels: This argument specifies the levels of hierarchy, consistent with the corresponding argument to the $dumpvars system task (see 1800-2012 section  21.7.1.2).
If this argument is not specified, it defaults to 0 (i.e., the specified module and in all module instances below the specified module).
Example: $dumpvars (1, top); // Because the first argument is a 1,                             // this invocation dumps all variables within the module top;                             // it does not dump variables in any of the modules instantiated by module top.
— list_of_scopes_or_assertions: This argument specifies which scopes of the model to control.  These arguments can specify any scopes or individual assertions.   For example,
module akill;    // /ch4/4.2/akill.sv
  bit clk, a,b;  default clocking @(posedge clk); endclocking   ap_kill: assert
  property (a |=> b) $assertkill(0, akill.ap_test_kill);
  ap_kill0: assert property(a |=> b) $assertcontrol(5, 15, 7, 0, akill.ap_kill0);
  3. Papers:
