IMPORTANT NOTICE: Please be advised that the Verification Academy Forums will be offline for scheduled maintenance on Sunday, July 5th at 3:00 AM US/Pacific.
In reply to saritr:
// Requirements are ambiguous as to should happen with the responses to the "rd_en"s in between the
// first rd_en and xn_valid. For example,
// What should xn_valid be in response to rd_en==1 @ cycle 4 and 5?
Below is one understandng where the rd_en excudes other rd_en to be considered in the assertion. You need to clarify your requirements, and that is the beauty of assertions, they force to be clear on intent.
interface tx_interface (input bit clk, input bit srstn);
//dut input
logic [15:0] xi;
logic [15:0] xq;
logic cyc_tic;
logic xn_valid;
logic rd_en;
initial forever #10 clk=!clk;
bit go=1'b1; // used for exclusivity
function void set_go(bit a);
go=a;
endfunction : set_go
// Assertion with exclusivity
ap_exclusive: assert property((rd_en && go, set_go(1'b0))
|-> ##5 (xn_valid, set_go(1'b1)) ) else set_go(1'b1);
// Assertion that for every rd_en then 5 cycles later xn_valid
ap_every: assert property(rd_en |-> ##5 xn_valid);
//dut output
logic [15:0] yi;
logic [15:0] yq;
endinterface
