Hi All,
I am having 2 questions
1.
real vout1;
at reset vout1 ='z;
how to check that in assertion ?
$isunknown(vout1) is not working.
- how to limit the assertion to check upto x decimal. (x =1,2,3,4)
example real vout2 = 3.2100002345;
thanks
Hi All,
1.
real vout1;
at reset vout1 ='z;
thanks
In reply to Abhisek11:
You’ll need to do type conversions.
See system verilog - The best way to convert a real valued number to an integer value larger than 32 bits? - Stack Overflow
module m;
real vout1 = 'Z, test_;
real test_value;
typedef logic [41:0] uint42_t;
uint42_t v42;
//A implicit cast from real to integral gives you what you want with rounding
test_value = 2.0 ** 39.5;
// Or you can use an explicit cast
// typedef logic [41:0] uint42_t;
test_value = uint42_t'(2.0 ** 39.5);
v42 = uint42_t'(vout2);
v42 = uint42_t'(vout1);
am_vout1 : assert ($isunknown(v42)); // line 17
// Simulation
// Error: Assertion error.
// Time: 0 ns Scope: m.am_vout1 File: C:/ben_play/./real2int.sv Line: 17
#10;
v42 = v42 | 10'b0000xzzz00;
am_vout : assert ($isunknown(v42));
