Assertion to check for the toggle (0->1) of a signal
Hi Ben,
I used the below code you had suggested to check the toggle of a signal.
assert_check: assert property (@(posedge clk) s_eventually $rose(sig1));
But I an facing an issue with this.
Suppose, 0 to n clock cycles are there in my simulation and the $rose(sig1) is coming after x clock cycles.
Then this assertion is showing errors for the (n-x) clock cycles, because after x clock cycles also it is expecting $rose(sig1) to come, but ideally it should check only once of $rose(sig1) throughout the signal.
Please suggest.
thanks & regards,
sanjoy
