Assertion modelling using time delay
Problem Statement: When Signal A is de-asserted and within 700ns Signal B should be de-asserted. This property should be re-usuable.
Current Code:
property delay (logic a,logic b, time delay);
time t_v[2];
@(posedge a)(1, t_var[0] = $realtime) ##0 @(negedge b)(1, t_v[1] = $realtime) ##0(t_v[1] - t_v[0]) <= delay;
delay_s1 : assert property (@(posedge rst) delay(a_1, b_1, 700ns));
delay_s2 : assert property (@(posedge rst) delay(a_2, b_2, 700ns));
Problem with the above code: Since i am using edge as my comparing some cases property fails incorrectly, how can I use a assert property for time delay based on level sensitivity.
Problem Statement: When Signal A is de-asserted (from 0 to 1)
and within 700ns Signal B should be de-asserted (from 1 to 0).
// minor corrected Code:
property delay (logic a,b, realtime delay);
        realtime t_v[2];
I don’t understand the issue. Elaborate with an example.
Ben systemverilog.us
realtime t_v[2];
*** I am not able to attach an image here which can probably explain the corner case better**
Example Corner Case:
  1. When the (posedge a) happens and if the value of b is already low(0), what it does is it looks for the next negedge of b and calculates the delay. This would cause an incorrect failure, since b is already low the property shouldn’t have failed
I have the solution if i use a clock but i am trying to find a way without using one
The following code doesn’t trigger the assertion for the actual failing case:
realtime t_v[2];
disable iff (b === 0)[/b]//change from the original code
In general what is the best practice to write an assertions for time delay between two events asynchronously?
In reply to matz25:
You’ll need to show me your model and issue.
I rewrote your assertion:
property p_delay (logic a,b, realtime delay);
        realtime t_v[2];
        @(posedge a)(1, t_v[0] = $realtime) ##0 @(negedge b)(1, t_v[1] = $realtime) ##0(t_v[1] - t_v[0]) <= delay;
    delay_s1    : assert property (p_delay(a, b, 750)) -> e1;
    delay_s2    : assert property (p_delay(a, b, 700ns)) -> e2;
Below are links to the testbench and image. Seems tot work OK.
If you have trouble putting the image on a web site (like google photo), you may email your test code and image at ben@SystemVerilog.us
http://systemverilog.us/vf/delay_test2.sv
  2. SVA: Package for dynamic and range delays and repeats - SystemVerilog - Verification Academy
