I want to write an assertion checker for synchronization of reset.In the below snap when dss_reset_in is de-asserted then after 4 clock cycles dss_reset_out to be de-asserted. Another thing i want to state here that this 4 clock cycle is a variable. I mean user will set after how many clock cycles dss_reset_out to be de-asserted after de-assertion of dss_reset_in.
In reply to SUBHAM RAY SINGH :
The simplest way to handle dynamic repeats, range repeats, delays, and range delays is to use my SVA Package: Dynamic and range delays and repeats SVA: Package for dynamic and range delays and repeats | Verification Academy
import sva_delay_repeat_range_pkg::*;
bit clk, dss_reset_in, dss_reset_out;
int d1=4;
initial forever #10 clk=!clk;
//when dss_reset_in is de-asserted then after 4 clock cycles dss_reset_out to be de-asserted.
// ****** DYNAMIC DELAY ##d1 **********
// Application: $rose(a) |-> q_dynamic_delay(d1) ##0 my_sequence;
ap_dyn_delay: assert property(@ (negedge dss_reset_in) 1'b1 ##1
@(posedge clk) q_dynamic_delay(d1) ##0 dss_reset_out==1'b0);
always @(posedge dss_reset_in) begin
dss_reset_out <= 1'b1;
repeat(4) @(posedge clk);
dss_reset_out <= 1'b0;
bit a;
bit[2:0] c;
repeat (100) begin
@(posedge clk);
if (!randomize(a, c) with {
a dist {1'b1 := 1, 1'b0 := 10};
c inside {[3:6]};
`uvm_error("MYERR", "This is a randomize error");
if(a) begin
d1 <= c;
#2 dss_reset_in <= 1'b1;
#2 dss_reset_in <= 1'b0;
$finish;
Free books: Component Design by Example FREE BOOK: Component Design by Example … A Step-by-Step Process Using VHDL with UART as Vehicle | Verification Academy
Papers:
