In reply to ChChee:
You can write an assertion using the sampling_clock as your main clocking event and use req, ack, and clk as the module variables. The relationship between the clocking event and clk is not clear. Below are 2 solutions. The fork-join_any solution allows you to tune the assertion to your requirements.
module top;
`include "uvm_macros.svh"
import uvm_pkg::*;
bit sampling_clock, clk, req, ack;
event e0, e1, e2, e3, e4;
//assert_b2b_check_missing_ack: assert property (@(posedge sampling_clock) b2b_check_missing_ack);
//property b2b_check_missing_ack; // *** the clocking event is @(posedge clk) and not the sampling_clock
//code here are conceptual only, it's not a working codes
// @(posedge clk) $past(clk) == 0 |-> (##[0:$] changed(clk)) && req && !ack |-> !( (##[0:$] $stable(clk)) && req && !ack )
//endproperty
/* I wanted to screen the condition below (missing ack=1) in a sequence of:
1. clk off && req=1 && ack=0
2. clk active && req=1 && ack=0
3. clk off && req=1 && ack=0 */
/* - after req asserted, followed by at least 3 clk prior to ack assertion
- after req de-asserted, ack should also de-assert and followed by at least 3 clk pulses before clk off
- residue clk from previous req running in current req is allowed */
let tmax=10; // number of clk cycles after ($rose(req) && !ack)
// Possible assertion
ap: assert property(@ (posedge sampling_clock)
$rose(req) && !ack |-> ##[1:tmax] ack);
// Solution that can be more finely tuned.
task automatic checkack();
bit tmax_end, ack_end;
fork
fork1: begin
-> e0; // for debug
repeat(tmax) @(posedge clk);
tmax_end = 1'b1;
-> e1;
disable fork2;
fork2: begin
@(ack);
ack_end=1'b1;
-> e2;
disable fork1;
join_any
// $display("%t @join %t, err=%b", $realtime, $realtime, err);
if(tmax_end && !ack_end) begin
a_ackerr: assert (0);
-> e3;
always @(posedge sampling_clock) if($rose(req) && !ack) checkack();
1) SVA Package: Dynamic and range delays and repeats https://rb.gy/a89jlh
2) Free books: Component Design by Example https://rb.gy/9tcbhl
Real Chip Design and Verification Using Verilog and VHDL($3) https://rb.gy/cwy7nb
3) Papers:
https://verificationacademy.com/verification-horizons/july-2020-volume-16-issue-2
https://verificationacademy.com/news/verification-horizons-march-2018-issue
