Assertion Check
In reply to rkg_:
Your requirements are not clear; I don’t understand your need for the case.
The caseis a property statement
property_statement ::=
property_expr ;
| case ( expression_or_dist ) property_case_item
{ property_case_item } endcase
| if ( expression_or_dist ) property_expr
[ else property_expr ]
// example
case (cntrl)
  2'd0 : a |=> c;
  2'd1 : a ##2 b;
  2'd2 : a ##1 b |-> c;
  default: 0;
endcase
// You could also use the **generate** statement.
// For your model, consider this (again, requirements ??)
/* if (a == 00) between 1 to 6 clock cycle of ref_clk if two positive edges of dec signal
   or incr signal is detected then lock is asserted.
   I am not sure how to check two positive edges of dec or incr on 1 to 6 clock cycle of ref_clk.
   Can i write case statement inside property since a can have 01 , 10, 11 as well so Do need to
   to write four separate property for (a == 2'b01, 2'b11 ..) ? */
   module m;
    bit[1:0] a, lock;
    bit ref_clk, inc, dec;
    property p_incdec;
        int inc_count, dec_count;
        (a==2'b00, inc_count=0, dec_count=0) |->
            (##1 (1, inc_count+= $rose(inc), dec_count+= $rose(dec)))[*6] ##0
            lock==(inc_count==2 || dec_count==2);
    ap_incdec: assert property(@ (posedge ref_clk)  p_incdec );
    generate for (genvar i=0; i<=3; i++)
            property p_incdeci;
                (a==i, inc_count=0, dec_count=0) |->
            ap_incdeci: assert property(@ (posedge ref_clk)  p_incdeci);
    endgenerate
    Real Chip Design and Verification Using Verilog and VHDL($3) https://rb.gy/cwy7nb
  3. Papers:
