Assertion check on delay
I was wondering if there is a way to do assertion check on signal which has a delay. But the delay of the signal is not fix for every test. All i need is to check that the signal has a delay before it gets the value from a specific signal.
For example, if A equal to 1, X ns later, B will equal to 1. But X is varies for every test.
In reply to lisa.lalice:
If the delay is in clock cycle, it is relatively simple, see the assertion ap_A2B below.
If the delay is in ns, it is more complicated. There, I used the task method explained in my paper Understanding the SVA Engine (link below), but modified it as needed.
Note that 1800’2017 addresses in 31.9.2 Conditions in negative timing checks the use of the $hold and there might be a way to use this. It’s been a very long time since I used this feature, so I’ll let someone else figure it out.
Basically, the process for my approach involves these steps
  1. Firing a task [b]t_chk_delayif the signal “a” changes @(posedge clk) [/b]
    This is a fire and forget (because of the join_none)
 always @(posedge clk) begin
if($changed(a))
t_chk_delay(2ns);
join_none
  1. Evaluating the task that forks 2 separate blocks, one with the specified delay, and one when the b==a (when “a” started). I then wait to figure out which one fininished first, and based on that determine if “b” occurred after “a” after the specified ns delay.
begin : d_dly
#d;
doned=1'b1;
end :d_dly
begin : change
wait(b == a_start); // b==a should occur after #d
done_chg=1'b1;
end : change
join_none
wait(doned || done_chg);
a_delay_bforeX: assert(doned && !done_chg) else  begin
// done delay before change in b
$display("%t spec delay=%t actual delay=%t",
$realtime, d, $realtime-initiTime);
-> e;
#3 a_equal_b_after_dly: assert(done_chg) else  begin
$display("%t spec NO CHANGE IN b, delay=%t actual delay=%t",
-> e1;
You may need to tune the code as needed, but this is my concept.
/* I was wondering if there is a way to do assertion check on signal which has a delay.
For example, if A equal to 1, X ns later, B will equal to 1. But X is varies for every test. */
    `include "uvm_macros.svh"
    import uvm_pkg::*;
    import sva_delay_repeat_range_pkg::*;
    bit clk, a, b;
    int d1=2; // in clock cycles
    event e, e1;
    // Assuming the delay in in clock cycles as defined in a module variable "d1"
    ap_A2B: assert property(@ (posedge clk) $changed(a) |->
                                            q_dynamic_delay(d1) ##0 $changed(b) );
     // Delay in ns
    task automatic t_chk_delay(realtime d);
        bit a_start, doned, done_chg; // done d delay, done change
        realtime initiTime;
        a_start=a;
        initiTime = $realtime;
            begin : d_dly
              #d;
              doned=1'b1;
            end :d_dly
            begin : change
                done_chg=1'b1;
            end : change
        join_none
                  -> e;
                  -> e1;
    endtask: t_chk_delay
       if($changed(a))
            t_chk_delay(2ns);
        join_none
       bit[2:0] v;
       bit a1, b1;
      repeat (200) begin
        @(posedge clk);
        if (!randomize(a1, b1, v) with {
          a1 dist {1'b1 := 1, 1'b0 := 1};
          b1 dist {1'b1 := 1, 1'b0 := 1};
          v  dist {2:= 1,     1 := 1,   4 := 1};
          `uvm_error("MYERR", "This is a randomize error");
        a = a1;
        #v b=b1;
      $finish;
// Error messages
               31 spec delay=                   2 actual delay=                   1
#                  155 spec NO CHANGE IN b, delay=                   2 actual delay=                   5
#                  170 spec delay=                   2 actual delay=                   0
# ** Error: Assertion error.
#    Time: 170 ns Started: 130 ns  Scope: top.ap_A2B File: C:/ben_play/chk_delay.sv Line: 13 Expr: $changed(b)
#    Local vars : v = 0
#    Time: 190 ns Started: 150 ns  Scope: top.ap_A2B File: C:/ben_play/chk_delay.sv Line: 13 Expr: $changed(b)
#                  195 spec NO CHANGE IN b, delay=                   2 actual delay=                   5
#    Time: 210 ns Started: 170 ns  Scope: top.ap_A2B File: C:/ben_play/chk_delay.sv Line: 13 Expr: $changed(b)
#                  290 spec delay=                   2 actual delay=                   0
#                  315 spec NO CHANGE IN b, delay=                   2 actual delay=                   5
#                  330 spec delay=                   2 actual delay=                   0
  3. Papers:
