I created a function for appending in_data (with in_data_offset) to out_data (at position out_data_pos)
// expected out data : xxxx1234abcdxxxx000000000000000000000000000000000000000000000000
// actual out data___: xxxxabcdxxxx0000000000000000000000000000000000000000000000000000
x +: N, The start position of the vector is given by x and you count up from x by N
x -: N, in this case, the start position is x and you count down from x by N
N is a constant and x is an expression that can contain iterators
this is an example from LRM, I think your mess up this syntax
function automatic void slice(ref logic[255:0] in_data, ref logic[255:0] out_data, input shortint in_data_offset, input shortint out_data_pos);
out_data = in_data<<in_data_offset; // shift in_data
out_data >>= out_data_pos; // start from this position
It works but it will loss the original first n bits (up to out_data_pos):
before in_data = 2222221234abcdxxxx0000000000000000000000000000000000000000000000
before out_data = eeeexxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
after out_data = 00001234abcdxxxx000000000000000000000000000000000000000000000000
expected = eeee1234abcdxxxx000000000000000000000000000000000000000000000000
Finally I use for-loop. It works but I want to learn a bit-shifting way. Please advise.
// filling out_data_pos up to last bit with in_data with offset
for (int i = 255 - out_data_pos ; i >= 0 ; i--) begin
int t = i + out_data_pos - in_data_offset;
if (t >= 0 || t <= 255) begin
out_data[i] = in_data[t];
your code has some issue, you need to handle out_data_pos greater or less than in_data_offset.
the out_data has 'hx in tail.
after out_data = eeee1234abcdxxxx0000000000000000000000000000000000000000000000xx (unknown)
As I mentioned, N has to be a CONSTANT, x allows variable.
i.g. fixed value or parameter size 10 for N … etc. this is LRM
Unless some compiler supports this new feature/request.
To meet your requirements, try this:
// support out_data_pos from 0 ~ 254 and 255
bit [255:0] mask = ((1 << out_data_pos) - 1) << (255 - out_data_pos + 1);
if (out_data_pos == 255) return;
out_data = (out_data & mask) |
((in_data << in_data_offset) >> out_data_pos);
