Based on the Number of slaves configured ,how to allocate the unique address ranges to each slave ?
Suppose let’s say Number of slaves = 4.
address [7:0]
In this case , slave1 address_range = [1:0];
slave2 address_range = [3:2];
slave3 address_range = [5:4];
slave4 address_range = [7:6];
This is my assumption.
If anything wrong , correct me.
Value ranges aren’t first class objects in SystemVerilog, so you can’t create instances of them. You’d have to use a min/max address value pair.
Hi Santi,
I assume that by “address ranges” you’re referring to address values not address bits.
If the slaves have equal address spaces then a common configuration would be this:
- address range of slave 0: [0…63]
- address range of slave 1: [64…127]
- address range of slave 2: [128…191]
- address range of slave 3: [192…255]
You can quickly identify the selected slave by looking at the last two msb of the address (e.g. if address[7:6] == 2’b10 then slave #2 is selected)
Hope this helps,
Cristi
In reply to Tudor Timi:
Thanks Tudor for your inputs.
Can You elaborate , how to slice the address based on the MIN/Max value Pair?
In reply to Cristian_Slav:
Thanks Cristian,
But how to make it customized?
Suppose let’s say I have configured number of slaves =8 and address width =16.
Then how to slice address range for each slave?
Regards,
Santi
In reply to Santi:
Hi Santi,
The algorithm is very simple. Here is a quick SystemVerilog implementation:
module tb;
automatic int address_width = 16;
automatic int number_of_slaves = 8;
automatic int slave_address_range = (1 << address_width) / number_of_slaves;
for(int slave_index = 0; slave_index < number_of_slaves; slave_index++ ) begin
automatic int min_addr = slave_address_range * slave_index;
automatic int max_addr = min_addr + slave_address_range - 1;
$display("slave #%0d range is [%0d..%0d]", slave_index, min_addr, max_addr);
Just be careful with shifting ‘1’ not to pass the ‘int’ limit.
Cristi
Thanks Cristian.
