Can base and derived class have same variable? and Is it possible to access derived class members with base class handle? Do we have any restriction in LRM for these?
// Code your testbench here
// or browse Examples
import uvm_pkg::*;
`include "uvm_macros.svh"
class parent_txn extends uvm_sequence_item;
rand bit [15:0] my_var; // 16-bit in parent
`uvm_object_utils(parent_txn)
function new(string name = "parent_txn");
super.new(name);
virtual function void display();
$display("Parent my_var = %0h", my_var);
class child_txn extends parent_txn;
rand bit my_var; // 1-bit in child (shadows parent's my_var)
`uvm_object_utils(child_txn)
function new(string name = "child_txn");
super.new(name);
$display("Child my_var = %0b", my_var);
$display("Parent my_var from child = %0h", super.my_var);
class my_sequence extends uvm_sequence;
parent_txn txn;
`uvm_object_utils(my_sequence)
function new(string name = "my_sequence");
super.new(name);
task body();
txn = parent_txn::type_id::create("txn");
// Assign values
txn.my_var = 1'b1;
// Call display function
txn.display();
// Add uvm_info to print values
`uvm_info("SEQ", $sformatf("Child my_var = %0b, Size my_var = %0h", txn.my_var, $bits(txn.my_var)), UVM_LOW)
`uvm_component_utils(my_test)
parent_txn txn; // Global handle
super.new(name, parent);
my_sequence seq = my_sequence::type_id::create("seq");
phase.raise_objection(this);
// Factory override to create child_txn
parent_txn::type_id::set_type_override(child_txn::get_type());
seq.start(null);
// Store the object handle from the sequence
txn = seq.txn;
phase.drop_objection(this);
run_test("my_test");
