I want to access the reset signal from testbench top level in test or sequence. In testbench I have the reset signal declared as
reg rst;
rst = 1'b0;
#10;
rst = 1'b1;
v_intf intf(clk,rst); // interface instance
uvm_config_db#(virtual v_intf)::set(null,"*","intf",intf);
run_test();
I want to access this “rst” signal in my test/sequence (any solution is fine). How can I access “rst” so that I can set value after my sequence completes.
So in my test after seq.start(env.agent.sqr) completes then I want to access this “rst” signal to set value. I tried
class base_test extends uvm_test;
virtual v_intf intf;
virtual function void build_phase();
super.build_phase(phase);
if(!uvm_config_db#(virtual v_intf)::get(this,"","intf", intf))
`uvm_error(get_type_name,"not got interface handle")
phase.raise_objection(this);
seq.start(env.agent.sqr);
join
$root.intf.rst = 1'b0 //error here, i want help with this line
phase.drop_objection(this);
but didn’t work for me. I got error saying,
*E,ILLHIN illegal location for a hierarchical name (in a package)
Thank you.
