Hi guys
am getting the syntax error at non overlapped operator which is shown below, can you people plz check and tell me as soon as possible
am writing assertion for FSM to verify the states
property peak; @(posedge clk) ( {(present_state == state0) && ( in |=> present_state == stste1 ), abort(!rst) });
a:assert property(peak)
Implication operators can only be used inside property expressions. Where you’re using it, it is inside a sequence expression, hence the syntax error.
Can’t help you rewrite that though, as you didn’t describe what the property is supposed to do, and I can’t make it out from your code.
user49
July 22, 2018, 4:49pm
3
In reply to warnerrs :
You don’t need to write a separate property if the assertion does not have arguments or if the assertion does not use local variables.
Use the default clocking @(posedge clk); endclocking instead of defining the clock in every assertion.
On signal notations, I like the _n for active low variables
ap: assert property(@ (posedge clk) // not needed if using default clocking
disable iff ($sampled(!rst_n)) // glitch free disable using the $sampled function
(present_state == state0) && in |=> present_state == state1);
// disable iff (!rst_n) // async disable
VF Horizons:PAPER: SVA Alternative for Complex Assertions | Verification Academy
http://systemverilog.us/vf/SolvingComplexUsersAssertions.pdf
“Using SVA for scoreboarding and TB designs”
http://systemverilog.us/papers/sva4scoreboarding.pdf
“Assertions Instead of FSMs/logic for Scoreboarding and Verification”
October 2013 | Volume 9, Issue 3 | Verification Academy
SVA in a UVM Class-based Environment
user49
July 23, 2018, 2:04pm
4
In reply to ben@SystemVerilog.us :
Keep in mind that an assertion of that type is similar to an enabled FF.
More interesting assertions address the requirements of the design.
Ben systemverilog.us
