A SVA question about how to check a signal will be asserted or de-asserted within a particular timing?
Hi Ben,
I have a similar scenario where I want a signal named ‘b’ to be asserted within some time ‘t’ after a signal ‘a’ is asserted. But for my case, the time ‘t’ is variable. I have coded an assertion property like this.
assert property(clk,a,b,t)
@(posedge clk)
    $rose(a) |-> ##[1:t] $rose(b);
But I am getting the following error:
Error-Illegal use of non-constant expression
The use of a non-constant expression is not allowed in properties, sequences
and assertions for cases such as delay and repetition ranges.
Please replace the offending expression by an elaboration-time constant
Can you please help me out?
Thanks,
Rajesh
