Hi, I am looking for assistance on the randomization of the input variables of FIFO.
In reply to abhishekk_07:
Lots of options, but one approach is to
- Define a transaction class that defines the variables that need to be randomized, along with their constraints.
- In the driver class, you randomize the instance of that transaction class and based on the randomized transaction (e,g, push, pop, idle) to call the needed task.
For example:
package fifo_pkg;
timeunit 1ns; timeprecision 100ps;
`define TOP fifo_tb
typedef enum {PUSH, POP, PUSH_POP, IDLE, RESET} fifo_scen_e;
class Fifo_xactn extends ....;
rand fifo_scen_e kind;
rand word_t data; // data to push
rand bit [7:0] idle_cycles;
rand bit [7:0] reset_cycles;
time xactn_time;
constraint cst_data {
data < 1024;
constraint cst_idle {
idle_cycles inside {[1:3]};
constraint cst_reset {
reset_cycles inside {[1:10]};
constraint cst_xact_kind {
kind dist {
PUSH := 400,
POP := 300,
PUSH_POP :=200,
IDLE := 30,
RESET := 10
} // cst_xact_kind
task Fifo_cmd_xactor();
Fifo_xactn fifo_xactn_0; // transaction to get
randomize(fifo_xactn_0);
case (fifo_xactn_0.kind)
PUSH :
this.push_task(fifo_xactn_0.data);
POP :
this.pop_task();
PUSH_POP :
this.push_pop_task(fifo_xactn_0.data);
IDLE :
this.idle_task(fifo_xactn_0.idle_cycles);
RESET :
this.reset_task(fifo_xactn_0.reset_cycles);
endcase
task Fifo_cmd_xactor::push_task (word_t data);
f_if.driver_cb.data_in <= data;
f_if.driver_cb.push <= 1'b1;
f_if.driver_cb.pop <= 1'b0;
@ ( f_if.driver_cb);
f_if.driver_cb.push <= 1'b0;
endtask : push_task
task Fifo_cmd_xactor::pop_task;
f_if.driver_cb.pop <= 1'b1;
endtask : pop_task
task Fifo_cmd_xactor::push_pop_task (word_t data);
endtask : push_pop_task
There are of course variations to this.
- SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
- A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
- Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
- Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 978-1539769712
- Component Design by Example ", 2001 ISBN 0-9705394-0-1
- VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
- VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
- SVA Alternative for Complex Assertions
Verification Horizons - March 2018 Issue | Verification Academy - SVA: Package for dynamic and range delays and repeats | Verification Academy
- SVA in a UVM Class-based Environment
SVA in a UVM Class-based Environment | Verification Horizons | Verification Academy - FREE BOOK: Component Design by Example … A Step-by-Step Process Using VHDL with UART as Vehicle | Verification Academy
