Could someone please explain me when I should use ‘assert property’ and when ‘cover property’?
Is this just a matter whether the simulator will count hits and misses for each of the property? Will usage of ‘cover property’ slow down the simulation?
If so, why not always to use both of them? ‘assert’ will check a failure of the rule/property, ‘cover’ will check whether the rule/property was ever fulfilled…
For example:
sequence s;
@(posedge clk) a ##1 b;
endsequence
property p;
a |-> s;
assert property (p);
cover property (p);
The difference is that covering a property ignores the failures, and asserting a property ignores the passes. Actually, you have a choice with an assert, You may want to know that it passed at least once, and never fails.
An assertion that fails usually invalidates the entire test and all associated coverage you have collected for that test.
In reply to cool_cake20:
It will be in your coverage report generated by your tool.
Hi Dave,
Is there a way I can get the coverage info about the assertion during the simulation? I have written a cover property and during the simulation, I want to check if its covered (i.e. passed at least once). I can get such coverage info if I use covergroup but I wanted it with cover property.
While I was browsing more on the question I asked, I came across system calls like $coverage_get using API, but I couldn’t figure out a way to implement them. Alternatively, I was also wondering if there is a way, I can set some variable or create an event the moment the defined property gets covered during runtime. I could then monitor any change in that variable to infer coverage.
While covergroup coverage can be tracked using .get_coverage, I feel it pretty lame that SV doesn’t have such a feature for cover property unless I’m missing something.
In reply to VB:
I provide an explanation in the use of APIs in my SVA Handbook.
The following is a copy of those pages. http://systemverilog.us/sva_api.pdf
It should help
Just to be sure - covergroup can be correlated to “cover property” - and language does provide statistics for both. The case of “assert” is slightly more involved and interesting. Compare that to a procedural scoreboard. Now, language does NOT give a way to get coverage stats for procedural code (To some extent there is a coverage API, but have not used that a lot).
There are many interesting cases with assert properties - much like branch coverage/path coverage etc. For inst:
a |=> b |=> c;
a |=> ##[1:5] b; // Did I get b after 1,2,3,4,5 clocks? Each could be a cover item
or, intersect, within, and → operators create even more complex cases.
In reply to VB:
a |=> b |=> c;
You may also be interested in “totally vacuous” reporting (tool dependent) https://vmmcentral.org/vmartialarts/2010/03/improved-productivity-with-vcs-assertion-indicators/index.html
Regards
Srini www.verifworks.com
I’m not sure if I’m missing something, but isn’t the “totally vacuous” scenario already addressed by cover property, which is like a flag whether the assertion has passed atleast once?
For example:
sequence s;
endsequence
property p;
a |-> s;
cover property (p);
When using both assert and cover on the same property, the coverage reports for the two simulators I use (Incisive and VCS) report 2 uncovered items for the same property. I find this annoying because I think I have twice as many uncovered items as I really have. For example, the report summary will say I have 10 uncovered assertions, but after I look at the details I realize I really only have 5 uncovered assertions. For this reason, I have stopped automatically adding a cover for each assert. I haven’t read anything in this good thread to convince me to do otherwise.
Perhaps other simulators or other tools (formal) use cover for different purposes.
Yes, all the good tools by default report coverage for each assert property. You can use cover property when you want to collect coverage based on temporal behavior of a signal. Meaning you are not checking protocol but a certain behavior. Collecting coverage on a temporal sequence using cover property is easier than writing SV Function Coverage.
Thanks for the reply.
Hi VB,
I am also looking for a technique to get the same results with cover properties as we get using get_coverage() with covergroups during runtime. Could you find a way to this with cover properties?
I have written assertions asserted using assert property, I am looking into functional coverage now, will these assertions be included in the coverage ? or I need to make use of cover property ?
