kishan
August 14, 2020, 3:44am
1
I have array bit [15:0] data.
I want to randomize it in such a way that , next data should be…
1st data → 16’h01_00;
2nd data → 16’h03_02;
3rd data → 16’h05_04;
How to write constraint for this?
In reply to Kishan_123 :
This is not a random pattern; you do not need constraints for this.
class A;
bit [15:0] data;
bit [7:0] counter
function void pre_randomize;
data[7:0] = counter++;
data[15:8] = counter++;
kishan
August 14, 2020, 9:23am
3
In reply to dave_59 :
Thanks Dave.
If array width is configurable like 8,16,32,64. then i have written like this.
bit [7:0] counter;
data.rand_mode(0);
if(width==8) begin
if(width==16) begin
else if(width==32) begin
data[23:16] = counter++;
data[31:24] = counter++;
else if(width==64) begin
data[39:32] = counter++;
data[47:40] = counter++;
data[55:48] = counter++;
data[63:56] = counter++;
but this is not good way to code. can you help me to do it in more generic way?
In reply to K_123 :
class a;
rand bit[7:0] data_q[$];
int size =2; //user controlled, not rand, legal values 1,2,3,4 for 32 bit data size
bit [31:0] data; //final output
constraint data_size_c {
data_q.size() == size;
foreach (data_q[i]) if (i!=0) {data_q[i] == data_q[i-1] +1;}
data_q[0] == const'(data_q[$]) + 1;
//data = {<<8{data_q}};
foreach(data_q[i]) data[i*8+:8] = data_q[i] ;
endfunction:post_randomize
endclass:a
Edit, save, simulate, synthesize SystemVerilog, Verilog, VHDL and other HDLs from your web browser.
you can parameterize the data width, something like
bit[MAX:0] data ;
and use any value on size…no change to constraints
In reply to K_123 :
That’s new information.
for(int i = 0;i<width'i+=8)
data[i+:8] = counter++;
BTW, Please use code tags making your code easier to read. I have added them for you.
juhi_p
August 17, 2020, 11:06am
7
class abc;
rand bit [15:0] data;
constraint data_c {data[15:8]==data[7:0]+1;};
constraint data_valid {data[7:0]==const'(data[7:0]) +2;};
module top;
abc a1;
a1=new();
for (int i=0; i<10;i++)
assert(a1.randomize());
$display("data=%h",a1.data);
I use this code, but output is :
# vsim -voptargs=+acc=npr
# run -all
# data=0302
# data=0504
# data=0706
# data=0908
# data=0b0a
# data=0d0c
# data=0f0e
# data=1110
# data=1312
# data=1514
# exit
which modification is required to cover 01_00?
In reply to juhi_p :
You can either start with initializing
data[7:0] = -2; , or write a more complex constraint
if const'(data[15:8]==0)
data[7:0] == 0;
else
juhi_p
August 17, 2020, 4:22pm
9
initializing data[7:0]=-2 didn’t work. but other solution did work.Thanks.
You could just initialize 0th element to 'h101 and keep adding 'h202 to previous element.
