I am trying to integrate my register model.
It looks like the below:
class a_reg_block extends uvm_reg_block;
`uvm_object_utils(a_reg_block)
rand a1_reg a1_reg_i;
uvm_reg_map a_map;
function new(string name = "a_reg_block");
super.new(name, UVM_CVR_ALL);
virtual function build();
a1_reg_i = a1_reg::type_id::create("a1_reg_i");
a1_reg_i.configure(this, null, "");
a1_reg_i.build();
a_map.add_reg(a_reg_i, 0, "RW");
lock_model();
For integration I created a handle in the sequencer of the system bus UVC. This is easy to configure and to access from the sequences.
The UVC structure is typical bus_env → bus_agent → bus_sequencer (going from top to down the hierarchy).
class bus_sequencer extends uvm_sequencer;
uvm_reg_block reg_block;
`uvm_component_utils_begin(bus_sequencer)
`uvm_field_object(reg_block, UVM_ALL_ON)
`uvm_component_utils_end
I’d like to replace the uvm_reg_block type with a_reg_block when I configure the environment so I use the set_inst_override_by_type command:
class a_tb extends uvm_component;
bus_env bus_env_i;
set_inst_override_by_type("bus_env_i.*reg_block", uvm_reg_block::get_type(), a_reg_block::get_type());
Unfortunately I get a runtime error saying:
UVM_ERROR @ 0: reporter [NOTYPID] get_type not implemented in derived class.
Does anyone can help why am I getting this error?
Thanks in advance,
Peter
In reply to Peter Simon:
Could you try
set_inst_override_by_type(uvm_reg_block::get_type(), a_reg_block::get_type(), "bus_env_i.*reg_block");
Looks to me that the prototype of this function is
set_inst_override_by_type (uvm_object_wrapper original_type, uvm_object_wrapper override_type, string full_inst_path);
, so seems there is mismatch between actual paramemter and formal parameter ?
In reply to caowangyang:
Hi Ceowangyang,
Thank you for your comment, but I am afraid that is not the solution.
I checked the prototype of the function in the UVM user guide. It says:
The prototype for uvm_component is
set_inst_override_by_type(string inst_path, orig_type, override_type);
I gave it a try anyway. Unfortunately I got the below error, that confirms that the original order of the argument was correct.
set_inst_override_by_type(uvm_reg_block::get_type(), a_reg_block::get_type(),“bus_env_i.*reg_block”);
ncvlog: *E,TYCMPAT (…/a_tb.sv,33|54): formal and actual do not have assignment compatible data types (expecting datatype compatible with ‘string’ but found ‘class uvm_pkg::uvm_object_wrapper’ instead).
ncvlog: *E,TYCMPAT (…/a_tb.sv,33|110): formal and actual do not have assignment compatible data types (expecting datatype compatible with ‘class uvm_pkg::uvm_object_wrapper’ but found ‘packed array’ instead).
I was referring UVM 1.1d, so not sure if it can explain the difference, anyway, looks like it is not the root cause, sorry about that.
I was thinking if the root cause is that uvm_reg_block wasn’t registered into factory. I saw register your specific derived class : a_reg_block with utility `uvm_object_utils, but I was wondering about that if UVM_LIB registered uvm_reg_block into factory ? Probably it is the cause ?
Hi Caowangyang,
Absolutely no need for apology, any input is very much appreciated. ;-)
I thought about the same thing, but I am afraid it is something I can’t solve, unless I create a wrapper class for uvm_reg_block, register it and later extend this to create a_reg_block. This sound a little dodgy, so if possible I’d avoid doing so.
Regards,
Peter
