Hello !
- Wanted to create a simple macro which represents the repeated code as show below. Simple code for getting a virtual interface and its often repeated. Wanted to create a macro which represents the code so that can pass the necessary input to the macro to mimic the code.
`define GET_VIF_HDL(VARIABLE_NAME, VARIABLE_FIELD_NAME, VARIABLE_VALUE) \
if (!uvm_config_db#(virtual ``VARIABLE_NAME``)::get(.cntxt(uvm_root::get()), .inst_name ("*"), .field_name(`"VARIABLE_FIELD_NAME`"), .value(``VARIABLE_VALUE``))) \
`uvm_warning(get_full_name(), $psprintf("GET_VIF_HDL: Unable to find the Handle For: VARIABLE_NAME: %p, VARIABLE_FIELD_NAME: %p!\n", ``VARIABLE_NAME``, `"VARIABLE_FIELD_NAME`")) \
else \
`uvm_info(get_full_name(), $psprintf("GET_VIF_HDL: Received the Handle For: VARIABLE_NAME: %p, VARIABLE_FIELD_NAME: %p!\n", ``VARIABLE_NAME``, `"VARIABLE_FIELD_NAME`"), UVM_HIGH) \
But when used inside any class by passing the interface name as VARIABLE_NAME during compilation it errors out saying, Undeclared Identifier as name is not visible in the respective area/context. But any reason why it’s throwing this error ? because expectation is the macro gets expanded with the passed in interface name and then gets compiled in the nxt step.
If the above is not possible, is there any other way to pass in the VARIABLE_NAME as string input and internally gets used as actual value ? So that way it does’t look for the existence of variable in that scope.
Please drop in your comments / suggestions.
**Working Example With the Error Info:
`include "uvm_macros.svh"
`uvm_warning("CLASS", $psprintf("GET_VIF_HDL: Unable to find the Handle For: VARIABLE_NAME: %p, VARIABLE_FIELD_NAME: %p!\n", ``VARIABLE_NAME``, `"VARIABLE_FIELD_NAME`")) \
else \
`uvm_info("CLASS", $psprintf("GET_VIF_HDL: Received the Handle For: VARIABLE_NAME: %p, VARIABLE_FIELD_NAME: %p!\n", ``VARIABLE_NAME``, `"VARIABLE_FIELD_NAME`"), UVM_HIGH) \
interface abc_interface;
logic what;
endinterface: abc_interface
class simpleclass;
virtual abc_interface abc_vif;
function get_vif();
`GET_VIF_HDL(abc_interface, abc_vif, abc_vif)
endfunction: get_vif
endclass: simpleclass
module simplertl;
simpleclass sc;
abc_interface abc_if();
uvm_config_db #(virtual abc_interface)::set(null, "*", "abc_vif", abc_if);
sc = new();
sc.get_vif();
endmodule: simplertl
Error Message:
xmelab: *E,CUVUNF (./simplertl.sv,18|56): Hierarchical name component lookup failed for ‘abc_interface’ at ‘$unit_0x7a60dc18’.
