Hi anyone,
Please clarify the below query
class seq extends seq1;
Seq3 seq_h;
task body();
'uvm_do(seq_h)
'uvm_do(seq_h)
join
In the above program,only one handle is created for class
seq3. While running the test was running properly.
Question: how single handle work for both uvm_do
In reply to Ganesan Thangarajan:
This works for simple cases where no reponses are required.
You need to look at how the `umm_do macro gets expanded for sequences. The macro creates a local variable that stores each handle. But if this body() needs to access one of the sequences, it only has access to the last sequence handle created.
Thanks for your response sir.
