I am seeing below information in UVM 1.1 class reference .
`uvm_do(SEQ_OR_ITEM)
This macro takes as an argument a uvm_sequence_item variable or object. The argument is created using `uvm_create if necessary.
Here does it mean that if object is already created for sequence item than it will not be created using ùvm_create ?
Because in the sentence it is mentioned that if necessary than only it will create .
In reply to ravin:
This was a mistake in the UVM 1.1 and 1.2 documentation. I it has been corrected in the upcoming UVM IEEE 1800.2 standard.
Here’s what that macro expands out to
uvm_sequence_base __seq;
uvm_object_wrapper w_;
w_ = SEQ_OR_ITEM.get_type();
$cast(SEQ_OR_ITEM , create_item(w_, m_sequencer, "SEQ_OR_ITEM"));
if (!$cast(__seq,SEQ_OR_ITEM))
start_item(SEQ_OR_ITEM, -1);
if ((__seq == null || !__seq.do_not_randomize) && !SEQ_OR_ITEM.randomize() with {} )
if (uvm_report_enabled(UVM_NONE,UVM_WARNING,"RNDFLD"))
uvm_report_warning ("RNDFLD", "Randomization failed in uvm_do_with action", UVM_NONE, "uvm_do.sv", 8);
finish_item(SEQ_OR_ITEM, -1);
else
__seq.start(m_sequencer, this, -1, 0);
We strongly recommend not using the `umm_do macro and instead learn the 4 simple steps to execute an item or the 3 simple steps to execute a sequence. From there you can modify the code to suit your needs.
ITEM_TYPE ITEM;
ITEM = ITEM_TYPE::type_id::create("ITEM"); // 1 create
start_item(ITEM); // 2 start_item
if (!(ITEM.randomize() with {/* your constraints */}) // 3 randomize
`umm_error("RNDFLD","Randomization failed")
finish_item(ITEM); // 4 finish_item
SEQ_TYPE SEQ;
SEQ = SEQ_TYPE::type_id::create("SEQ"); // 1 create
if (!(SEQ.randomize() with {/* your constraints */}) // 3 randomize
start(ITEM,this); // 4 start
In reply to dave_59: i am trying to override this UVM_WARNING with UVM_ERROR using set_report_severity_id_override(UVM_WARNING,“RNDFLD”,UVM_ERROR) but its not working. i am doing it in my environment and in end_of_elaboration_phase. am i doing it right?
i tried doing this in my environment and in base test but its not working. i also tried set_report_severity_override but no use. Appreciate your help on this. Thanks.
I agree but i am in middle of project and really have no time to change all the existing sequences. so i was trying to change severity of messages. any other alternative solution?
