I am trying to implement logic in driver class to check that rsp is asserted 8 clks after valid is asserted. Valid could be back to back.
Is there a better way to write it?
task run_phase();
@(posedge clk)
if(valid)begin
req_rsp_8_clks();
join_none
task automatic req_rsp_8_clks();
repeat(8)
@(posedge clk);
vif.rsp = 1'b1;
@(negedge clk)
vif.rsp = 1'b0;
I do not understand the question. Are you do a “check” on rsp or do you need to drive it? And do you mean to say that the 8 clock cycles could be overlapping?
task run_phase();
@(posedge clk)
if(valid)begin
req_rsp_8_clks();
join_none
repeat(8)
@(posedge clk);
vif.rsp = 1'b1;
@(negedge clk)
vif.rsp = 1'b0;
Your code is driving the rsp signal.
If you want to check the correct behavior of the rsp you might use a SV Assertion checker.
In reply to UVM_SV_101:
Hi dave,
Sorry for the confusion, I need to drive rsp 8 clks after I see valid. Yes 8 clks could be overlapping (consecutive valid)
Thats correct my code is driving the rsp signal. I am creating another thread for how to writing assertion to check the same…
