Issue with triggering event using uvm_event
I have two uvm components producer and consumer, which are connected in test_lib.sv. I have declared an event in consumer and I wait for that trigger. The display after event wait is not printed. I think the trigger not happening properly, Am I MISSING ANYTHING?
I am giving an executable code here:
filename: filelist.svh
`include "uvm_pkg.sv"
`include "axi_tx.sv"
`include "producer.sv"
`include "consumer.sv"
`include "top.sv"
filename: axi.tx.sv
class axi_tx extends uvm_sequence_item;
	bit [31:0] awaddr;
	bit [2:0] awburst;
	bit [2:0] awsize;
	bit [3:0] awlen;
	bit [31:0] wdata[$];
	bit test_bit;
	`uvm_object_utils_begin (axi_tx) // add the following fields to existing methods (pack,print,compare,etc..)
		`uvm_field_int(awaddr, UVM_ALL_ON);
		`uvm_field_int(awburst, UVM_ALL_ON);
		`uvm_field_int(awsize, UVM_ALL_ON);
		`uvm_field_int(awlen, UVM_ALL_ON);
		`uvm_field_queue_int(wdata, UVM_ALL_ON);
	`uvm_object_utils_end
	function new (string name ="");
filename: top.sv
module top;
	`include "test_lib.sv"
	 run_test();
filename: test_lib.sv
	producer prod_h;
	consumer cons_h;
	uvm_table_printer printer_h;
	function new (string name="", uvm_component parent=null);
		super.new(name,parent);
		printer_h=new();
		prod_h = producer::type_id::create("prod_h",this);
		cons_h = consumer::type_id::create("cons_h",this);
		super.connect_phase(phase);
		// connection  between prod and cons
		prod_h.put_port.connect(cons_h.put_imp); //
	function void end_of_elaboration_phase (uvm_phase phase);
		`uvm_info(get_type_name(), $psprintf("Printing the test topology : \n%s", this.sprint(printer_h)), UVM_LOW); // (ID,msg,verbosity)
				// sprint returns as string
filename: producer.sv
class producer extends uvm_component;
	`uvm_component_utils(producer)
	uvm_blocking_put_port#(axi_tx) put_port; // put_port of producer
        axi_tx tx;
		put_port = new("put_port", this);
                 repeat(3) begin
			tx = axi_tx::type_id::create("tx");
			assert(tx.randomize());
			tx.test_bit = 1;
			put_port.put(tx); // defined put in consumer
filename:consumer.sv
class consumer extends uvm_component;
	`uvm_component_utils(consumer)
         uvm_blocking_put_imp#(axi_tx, consumer) put_imp;
         uvm_event event_h;
		put_imp = new("put_imp", this); // use it for consumer without subcomponents
		event_h = new("event_handle");
		//event_h.reset();
        task dummy_print();
           $display("display before event wait");
           event_h.wait_trigger(); // waiting for the event
	   $display("event triggered due to bit set to 1"); // issue here, am I not getting this print ?
        task put(axi_tx tx1);
		$display("consumer received contents");
                $display("test_bit = %0d",tx1.test_bit);
		//tx1.print();
		if (tx1.test_bit == 1) begin
			$display("test_bit condition satisfied");
                          $display("event trigger at time %0t", $time);
                          #10; // intentionally delaying to make dummy_print task to be called first
			  event_h.trigger();
			  //event_h.is_on();
			  $display("calling dummy_print task in put imp");
                	  dummy_print();
                        join
Thanks your help is appreciated.
In reply to rakesh2learn:
Hi
  1. Close the fork construct with “join”.
  2. Remove the delay.
Now run.
@Sunils ok “join” was missing in consumer component when I pasted here. It was a typo. However why i should remove the delay? Moreover removing delay also doesn’t fix the issue.
Here is the output in QuestaSim after using fixes:
# Name          Type                   Size  Value
# uvm_test_top  base_test              -     @457
#   cons_h      consumer               -     @473
#     put_imp   uvm_blocking_put_imp   -     @481
#   prod_h      producer               -     @465
#     put_port  uvm_blocking_put_port  -     @491
# consumer received contents
# test_bit = 1
# test_bit condition satisfied
# event trigger at time 0
# calling dummy_print task in put imp
# display before event wait
# event triggered due to bit set to 1
# test_bit = 1
# test_bit = 1
# --- UVM Report Summary ---
# ** Report counts by severity
# UVM_INFO :    4
Why you are putting the delay?
that is very strange. I didn’t get that display.
This is my output.
# uvm_test_top  base_test              -     @490
#   cons_h      consumer               -     @506
#     put_imp   uvm_blocking_put_imp   -     @514
#   prod_h      producer               -     @498
#     put_port  uvm_blocking_put_port  -     @524
# test_bit = 1
# event triggered at time 0
# display before dummy_print
# UVM_INFO :    3
To debug your problem you can make the following modification in the consumer code:
replace the fork/join with a fork/join_any. Then you see the second process in this concurrent process is called first. I believe it is not a good idea to use the wait_trigger and trigger in the same process.
