I have two uvm components producer and consumer, which are connected in test_lib.sv. I have declared an event in consumer and I wait for that trigger. The display after event wait is not printed. I think the trigger not happening properly, Am I MISSING ANYTHING?
I am giving an executable code here:
filename: filelist.svh
`include "uvm_pkg.sv"
import uvm_pkg::*;
`include "axi_tx.sv"
`include "producer.sv"
`include "consumer.sv"
`include "top.sv"
filename: axi.tx.sv
class axi_tx extends uvm_sequence_item;
bit [31:0] awaddr;
bit [2:0] awburst;
bit [2:0] awsize;
bit [3:0] awlen;
bit [31:0] wdata[$];
bit test_bit;
`uvm_object_utils_begin (axi_tx) // add the following fields to existing methods (pack,print,compare,etc..)
`uvm_field_int(awaddr, UVM_ALL_ON);
`uvm_field_int(awburst, UVM_ALL_ON);
`uvm_field_int(awsize, UVM_ALL_ON);
`uvm_field_int(awlen, UVM_ALL_ON);
`uvm_field_queue_int(wdata, UVM_ALL_ON);
`uvm_object_utils_end
function new (string name ="");
super.new(name);
filename: top.sv
`include "test_lib.sv"
run_test();
filename: test_lib.sv
class base_test extends uvm_test;
producer prod_h;
consumer cons_h;
uvm_table_printer printer_h;
`uvm_component_utils(base_test)
function new (string name="", uvm_component parent=null);
super.new(name,parent);
printer_h=new();
super.build_phase(phase);
prod_h = producer::type_id::create("prod_h",this);
cons_h = consumer::type_id::create("cons_h",this);
super.connect_phase(phase);
// connection between prod and cons
prod_h.put_port.connect(cons_h.put_imp); //
function void end_of_elaboration_phase (uvm_phase phase);
`uvm_info(get_type_name(), $psprintf("Printing the test topology : \n%s", this.sprint(printer_h)), UVM_LOW); // (ID,msg,verbosity)
// sprint returns as string
filename: producer.sv
class producer extends uvm_component;
`uvm_component_utils(producer)
uvm_blocking_put_port#(axi_tx) put_port; // put_port of producer
axi_tx tx;
put_port = new("put_port", this);
repeat(3) begin
tx = axi_tx::type_id::create("tx");
assert(tx.randomize());
tx.test_bit = 1;
put_port.put(tx); // defined put in consumer
filename:consumer.sv
class consumer extends uvm_component;
`uvm_component_utils(consumer)
uvm_blocking_put_imp#(axi_tx, consumer) put_imp;
uvm_event event_h;
put_imp = new("put_imp", this); // use it for consumer without subcomponents
event_h = new("event_handle");
//event_h.reset();
task dummy_print();
$display("display before event wait");
event_h.wait_trigger(); // waiting for the event
$display("event triggered due to bit set to 1"); // issue here, am I not getting this print ?
task put(axi_tx tx1);
$display("consumer received contents");
$display("test_bit = %0d",tx1.test_bit);
//tx1.print();
if (tx1.test_bit == 1) begin
$display("test_bit condition satisfied");
$display("event trigger at time %0t", $time);
#10; // intentionally delaying to make dummy_print task to be called first
event_h.trigger();
//event_h.is_on();
$display("calling dummy_print task in put imp");
dummy_print();
join
Thanks your help is appreciated.
