Here is a sample code of what I’m working on
class c_cfg extends uvm_object;
rand bit c_bit;
constraint c_turnoff {
c_bit == 1'b0;
endclass: c_cfg
2nd file
class b_cfg extends uvm_object;
rand c_cfg cfg_c;
endclass: b_cfg
main file
class a_cfg extends b_cfg;
// I want to overwrite the constraint in c_cfg here.
// I want that to be 1
endclass: a_cfg
I tried overwriting the constraint in c_cfg by using the same constraint name in a_cfg, but it doesn’t solve (I guess it is because in c_cfg and not in b_cfg) simulator is not able to solve the constraint. Then tried cfg_c.c_turnoff.constraint_mode(0); in the new function in a_cfg, but it still considers the constraint in c_cfg.
Can someone suggest how to do that.
