I am having one Register defined with some fields. 32-bits wide Register R1 with fields F1, F2, F3, F4 - each 8 bits wide.
Now for backdoor check, I want to set UVM_NO_CHECK for bit 0 of R1, means F1[0].
reg.get_field_by_name[“F1”].set_compare(UVM_NO_CHECK) will disable checking for complete field F1, but I just want to disable check for F1[0].
Can someone please help to find approach for this one ?
Kavish
chr_sue
February 27, 2018, 9:19am
2
In reply to shahkavish77 :
In my understanding the samllest unit in the register model is the field. You can perform this chek or not. If you want to have a smaller granularity I’d recommend to mask certain bits.
cuonghl
February 27, 2018, 9:40am
3
UVM reg doesn’t allow you to do something like that. You have to check it manually:
Get expected mirror value
Get actual backdoor value
Compare these values with masking F1[0]
