How To Run Script Files in Questa Sim (I am Facing Problem while Running Sript Files)
QuestaSim>help make
No help for make available.
QuestaSim>help makefile
No help for makefile available.
QuestaSim>help make
QuestaSim>make -f Makefile
wrong # args: should be “make_rpc_server”
QuestaSim>make -f questa
QuestaSim>make -f questa.mk
The above all are Error while i am Running Script Files on Questa sim 10.0b Can you Please any one Guide How run Script Files and Provides the Necessary Tool Commands.
The Script Files are Located in run directory of the Following Link :- GitHub - cluelogic/uvm-tutorial-for-candy-lovers: Source code repo for UVM Tutorial for Candy Lovers
Thanks&Regards
Balaji,
You need to run make from a Linux shell. If you are running Windows, you will need to contact the author of the tutorial for instructions.
BTW Questa 10.0b is very old for running UVM examples.
[Status => Task Incomplete Can’t Find a Solution for my Problem,Help me to Find Out]
Here the Author is Giving the Limited Instructions Through README.md file.First of all i can’t able to understand it Completely. Even If i am following that file means i can’t able to Compile the TB. So If you have any idea on Compiling Script Files Please Go through README.md file avialable in this Link Updated README.md. · cluelogic/uvm-tutorial-for-candy-lovers@e9f529e · GitHub can you please tell me what steps i need to follow to Achieve the Simulation Results
Balaji
In reply to balaji2birla:
Balaji
I downloaded and tried the example.
On Linux, you open a shell and go into the run directory.
You can use the makefile provided.
To compile and run a test : make questa TUTORIAL=1
If you are running on Windows, then the makefile won’t work.
The makefile contains shell commands that are not understood on Windows.
I converted the commands in the Makefile to TCL, so they will work on any operating system
Save the following lines into a file called sim.do that is located in the run directory.
Then invoke Questa and you can execute a test by going
do sim.do 1 -: runs test #1
do sim.do 7 -: runs test #7
Graeme
echo “ARGS = $argc”
set TUTORIAL $argc
switch $TUTORIAL {
1 {set tutorial_file tutorial_1_to_6.sv
set testname jelly_bean_test}
2 {set tutorial_file tutorial_1_to_6.sv
3 {set tutorial_file tutorial_1_to_6.sv
4 {set tutorial_file tutorial_1_to_6.sv
5 {set tutorial_file tutorial_1_to_6.sv
6 {set tutorial_file tutorial_1_to_6.sv
7 {set tutorial_file tutorial_7_and_8.sv
set testname jelly_bean_recipe_test}
8 {set tutorial_file tutorial_7_and_8.sv
9 {set tutorial_file tutorial_9.sv
set testname jelly_bean_reg_test}
15 {set tutorial_file tutorial_15.sv
21 {set tutorial_file tutorial_21.sv
default {
expr {3}
Constants
set src_dir …/src
set compile_files $src_dir/$tutorial_file
set compile_opts +define+TUTORIAL=$TUTORIAL
set run_opts +UVM_TESTNAME=$testname
set top_module top
set QUESTA_LIB_DIR ./work
set QUESTA_LIB_NAME work
set questa_compile_opts “$compile_opts +define+CL_USE_QUESTA”
set questa_run_opts $run_opts
set questa_run_cmd_file modelsim.cmd
vlib $QUESTA_LIB_DIR
vmap $QUESTA_LIB_NAME $QUESTA_LIB_DIR
vlog $questa_compile_opts $compile_files
vsim $questa_run_opts $top_module -do $questa_run_cmd_file
