How to escape in while(1)?
Regarding for understanding, All run_phase tasks in all components get killed when the last objection drops.
https://verificationacademy.com/forums/uvm/how-end-simulation-when-there-are-forever-loops-sequence-and-monitor
I expected the while(1) will be killed when the drop objection.
but as you can see the below code, while(1) was not killed because never meet drop_objection().
So When we use forever statement in raise/drop_objection(), how to escape it? Could you guide me how to deal with forever statement?
    phase.raise_objection(this);
        fork begin
            while(1) begin
                if(compC.m_analysis_fifo.is_empty) `uvm_info(get_type_name(),"UVM_TLM_ANALYSIS_FIFO compC is Empty", UVM_LOW)
                #5;
       join_any
       disable fork;
    phase.drop_objection(this);
In reply to UVM_LOVE:
The following are all equivalent loops.
forever // recommended as this shows the clearest intent
    statement;
while(1)
    statement;
for(;;)
    statement;
do
    statement;
  while (1);
There are two ways to escape these loops.
  1. execute a break statement within the loop.
  2. terminate the process executing the loop.
Normally you would not put a raise/drop objection in a phase containing an infinite loop. Some other component like the test would have the calls to raise/drop objection. When there are no more outstanding objections, the UVM terminates all processes in that phase.
statement;
while(1)
statement;
for(;;)
statement;
do
statement;
while (1);
Thank you dave.
If you don’t mind would you please let me know the example case of “terminate the process executing the loop.”?
