//this is the driver class where i replace my uvm_error to uvm_info but its not changed to uvm_error to uvm_info
if(!uvm_config_db #(int)::get(null,get_full_name(),“var”,var2))
`uvm_error("hi","not able to get value")
else
`uvm_info ("GETTING VALUES IN CALLBACKSHHHSGSHS-PASS", $sformatf("var2=%0d", var2),UVM_NONE)
//i have written syntax for this severity in test class to override . its not working what are changes that i have to do??
function void set_report_severity_id_override( uvm_severity UVM_ERROR,
hi,
uvm_severity UVM_INFO);
