I have register read sequence which I am invoking in the virtual sequence.
How can I get the read data i.e. response from the driver back to reg read sequence and then to virtual sequence.
How this can be achieved without using the configuration.
It’s a question of adding a data field to your register read sequence. When you get the response from the driver you assign it to the data field, then the virtual sequence can access this information from the sequence via a hierarchical reference to the data field.
