Hello !
- Say I have a top level reg block abcd_reg_block and has its default_map.
class abcd_reg_block extends uvm_reg_block;
- Also there are 4 sub reg blocks [a, b, c, d], added into the top abc_reg_block and the respective reg maps are added as sub_maps into to the top level reg_map, and also provided the respective base address offset.
a_reg_block a_rb;
b_reg_block b_rb;
c_reg_block c_rb;
d_reg_block d_rb;
abcd_reg_map.set_submap_offset(a_rb.default_map, 'hA050_0000)
- Now if I access using below code i.e. calling get reg by offset and provide the entire register address, will I get the link to the respective register which resides within a block inside the top level reg block ?
abcd_reg_block.default_map.get_reg_by_offset('hA050_001C);
Please provide your comments !
