Hi Guys,
I am wondering if the following can be done. Can i have a conditional check on the macro "`DC__NUM1" "`DC__NUM2" and based on that result, randomize with the following constraint. I am running into the following error:
Quote:
Error-[SE] Syntax error
95: token is 'begin'
phase.raise_objection(this);
//random settings
foreach(cfg_per_pipe[i]) begin
if (!cfg_per_pipe[i].randomize() with {
UPDATE_SAMPLE_RATE_COUNT_EN == 0;
SAMPLE_RATE_COUNT_EN_2 == 0;
SAMPLE_RATE_COUNT_EN_1 == 0;
[b] if(`DC__NUM1 != `DC__NUM2 ) begin
//fixed pipe setting
var_SOURCE_SELECT == i;
[/b]
}) `uvm_fatal(get_name(), $sformatf("cfg_per_pipe[%0d] randomization failed", i))
