I am trying to write a glitch checker(in the form of a system verilog task) on clocks. The glitch checker is able to detect the zero time glitches but it is not able to detect zero period glitches (when I say zero period glitch it means that 3 of the clock edges are happening at the same time). I tried couple of things in coming up with a solution for the above problem but in vain. I am trying to approach a problem based on scheduling semantics in system verilog but no successful results as of now. Has anyone on this forum faced a similar problem before? Or is there a solution possible to above problem considering the scheduling semantics of system verilog?
Hoping for a positive reply.
Thanks !!
