I am trying to assert this property:
assert_1:
assert property ( @(posedge clk) disable iff (!a)
(b == 1'b0) |-> (c == 1'b1) )
`uvm_error("ASSERT", "c cannot go high")
else `uvm_info("ASSERT", "c should be in high state after b bit is set",UVM_LOW)
What is wrong with this? and what does the following error mean?
xmsim: *E,ASRTST (…/bench/top/assertions.sv,204): (time 1500 NS) Assertion top.assertions.assert_1 has failed (2 cycles, starting 500 NS) 1500 NS + 3 (Assertion output stop: top.assertions.assert_1 = failed)
