As I know we cannot write tasks inside a function, so how can we write $display, $monitor inside functions. If we can then I want to know what is the difference between task and systemtask?
In reply to santosh_1004:
This is leftover terminology from Verilog where functions were required to have return values and arguments. Systemtasks should really be renamed System functions. See 0002027: calling system tasks from functions - Accellera Mantis
We can write task inside function. Please find below code for the reference
module task_function;
function call();
task_a();
task task_a();
#2 $display(“After 2 ns”);
#5 $display(“After 5 ns”);
join_none
initial
call();
#20 $display(“after function call”);
In reply to Arshia:
Hello Arshia,
I tried running your code in EDA Playground.
It showed…
ERROR VCP2802 “Function cannot enable a task.” “testbench.sv” 6 9
WARNING VCP2814 “Function call should return a value.” “testbench.sv” 4 15
WARNING VCP2803 “Function call result is ignored.” “testbench.sv” 19 7
FAILURE “Compile failure 1 Errors 2 Warnings Analysis time: 0[s].”
you can remove those warnings by specifying a return type but still functions can’t enable a Task.
Hi Santosh,
I guess due to simulator run.
I have used running the Synopsys Simulator and showing me the below result:
After 2 ns
After 5 ns
after function call
V C S S i m u l a t i o n R e p o r t
Time: 20 ns
Regards,
Arshia
In reply to Arshia:
SystemVerilog does not allow functions to have blocking statements, and explicitly;
A function shall not enable tasks regardless of whether those tasks contain time-controlling
statements.
This is a tool bug, If you used your function with a delay in an expression, it would not make any sense.
Thanks Dave for the confirmation!
