In reply to sai_pra99:
Your main issue here is that in the antecedent you are ANDing a logical variable (the “&”) with a sequence, and that is ILLEGAL. Specifically, you have
(p_wren && setup_state) // setup_state is declared as a sequence
// Thus, the compiler sees
sequenceA && sequenceB // p_wren is a sequence of 1 term.
// If you really want the AND, then you need the sequence AND operator, which is "and".
// I would use the Sequence fusion (##0) operator, Thus,
sequence setup_state;
(state==SETUP_PHASE);
endsequence
property stable_wr_data;
disable iff(!p_rstn)
@(posedge p_clk)
// (p_wren && setup_state) |-> ##1 !($isunknown(tmp_data) && $isunknown(tmp_addr));
(p_wren ##0 setup_state) |-> ##1 !($isunknown(tmp_data) && $isunknown(tmp_addr));
There are other things about your code that needs to corrected, from a style point of view.
- Don’t use a program, use a checker or a module
- You have way too many sequence declarations of 1 term, why not put them inline with your assertion or with your property.
- If a property is used once and does not have local variables, then put the property contents within the assertion.
ap_stable_wr_data: assert property( // better style
@(posedge p_clk)
p_wren && state==SETUP_PHASE |-> ##1 !($isunknown(tmp_data) && $isunknown(tmp_addr)) );
- Use the SystemVerilog style for port list, instead of Verilog style.
Real Chip Design and Verification Using Verilog and VHDL($3) Amazon.com - Papers:
SVA in a UVM Class-based Environment | Verification Horizons | Verification Academy - Understanding the SVA Engine,
Verification Horizons - July 2020 | Verification Academy
