Hi All,
Can anyone please tell me how to Add a ignore_bin for this vector signal WData_Stb (64 bit). the only legal values are when all the 1’s are continuous. It is allowed to have 0’s at either end of the vector, but there cannot be any 0’s between 1’s in the vector.
Instead of writing all the valid possible cases I thought it is better to add a ignore_bin for the invalid cases. How to do achieve this in system verilog in a simple way ?
WData_Stb_cp: coverpoint (intf.mon_cb.WData_Stb) iff (intf.mon_cb.WData_Rdy && intf.mon_cb.WData_Vld)
In reply to sriram_6869:
To enforce the constraint that all 1’s in the WData_Stb vector must be continuous, you can use the ignore_bins feature in SystemVerilog. The ignore_bins statement allows you to specify bins that should be ignored during coverage analysis.
Here’s an example of how you can add an ignore_bin to your covergroup to handle the cases where there are 0’s between 1’s in the WData_Stb vector:
covergroup WData_CG with function sample (logic [63:0] WData_Stb);
option.per_instance = 1;
WData_Stb_cp : coverpoint WData_Stb {
bins valid_data = {[1:$]} iff (isValid(WData_Stb));
// Ignore bins for invalid cases
ignore_bins invalid_data = {[1'b0]};
// Additional coverpoints or crosses as needed
// Function to check if the vector has continuous 1's
function bit isValid(logic [63:0] data);
logic [63:0] mask;
mask = data;
mask &= mask << 1;
return (mask == 0);
endgroup
// Instantiate the covergroup
WData_CG wdata_cg_inst;
// Sample the data
// Assuming some kind of sampling loop
repeat (1000) begin
logic [63:0] WData_Stb = /* your logic to generate WData_Stb */;
// Sample values
wdata_cg_inst.sample(WData_Stb);
// Add other sampling code as needed
// Report coverage at the end
wdata_cg_inst.report();
In this example:
The WData_Stb_cp coverpoint has a bin named valid_data that includes the range [1:$] (all 1’s). This bin is conditioned on the isValid function, which checks if the vector has continuous 1’s.
The ignore_bins statement is used to specify the invalid_data bin, which includes the value [1’b0]. This bin is ignored during coverage analysis.
The isValid function checks if the vector has continuous 1’s by creating a mask and comparing it with its left-shifted version. If they are equal, then there are no 0’s between 1’s. If they are not equal, then there are 0’s between 1’s, and the bin is ignored.
rahulvala@gmail.com
Freelancer/verification engineer
https://www.linkedin.com/in/rahulvala/
I’m not sure this is doing what’s described in the comment, e.g. try with 0010100. By shifting 1 zero left and bitwise AND you’ll end up with true as return value, which clearly is wing.
In order to check if there is at least one continuous sequence of 1s you may want to try this instead:
return (data & (data << 1));
If you want to make sure there’s only one continuous sequence of 1s that’s a little more involved.
EDIT: here’s the version to find only consecutive sequences of 1s, which is based on the premise that a consecutive sequence has a beginning and an end:
bit [64:0] result = data;
return $countones(result ^ (result << 1)) == 2;
Explanation: a sequence of 1s can have exactly two transitions, from 0 to 1 and from 1 to 0. We can identify those transitions by xor’ing the array with itself shifted by 1 left and then there’s nothing left other than counting the number of transitions. The extra bit in the result variable is to accommodate the transition to and from 0.
I believe this solution has a complexity of O(n), assuming the xor is a constant (but I guess that’s true as long as the operands fit in the arithmetic unit bus).
