Write constraint for an integer array with 10 elements such that exactly 3 of them are same and rest are unique
module abc;
  class aa;
    rand int unsigned val[10];
    rand int unsigned r_index1,r_index2,r_index3;
    constraint s1 {
      r_index1 inside {[0:9]};
      r_index2 inside {[0:9]};
      r_index3 inside {[0:9]};
      r_index1 != r_index2;
      r_index1 != r_index3;
      r_index3 != r_index2;
      foreach(val[i]){ val[i] < 10; }
      foreach(val[i]){
        foreach(val[j]){
          if(i != j && i!=r_index1  && j!=r_index1)
            val[i] != val[j];
        val[r_index1] == val[r_index2];
        val[r_index1] == val[r_index3];
    aa a1 = new();
    a1.randomize();
    $display(a1.r_index1, a1.r_index2,a1.r_index3);
    $display(a1.val);
Seems when i run this code,its going to infinite loop.May i know how to solve it.
In reply to dve12:
In the second foreach you meant a[i]!=r_index1 && a[j]!=r_index1 instead of i!=r_index1 && j!=r_index1.
module abc;
  class aa;
    constraint s1 {
      foreach(val[i]){
        val[i] < 10 ;  }
      foreach(val[i]){
        foreach(val[j]){
          if(i != j && val[i]!=r_index1  && val[j]!=r_index1)
            val[i] != val[j];
 aa a1 ;
    a1 = new();
    assert(a1.randomize());
    $display(a1.val);
In reply to dve12:
You have made the constraints much more complex than they need to be, And technically, you are not allowed a random index into a random array variable.
module abc;
  class aa;
    rand byte unsigned val[10], val3;
    constraint s1 {
      foreach(val[i]) {
        val[i] < 10;
        // every value except val3 must appear only once
        val[i] != val3 -> val.sum() with (int'(item==val[i]))== 1;
      // val3 must appear three times in the array
      val.sum() with (int'(item==val3)) == 3;
  aa a1 = new();
  initial repeat (10) begin
    a1.randomize();
    $display("%p %d", a1.val, a1.val3);
In reply to dve12:
This is one of the compact way I could think of
class generate_array#(parameter repeat_n = 3, parameter arr_size = 10, parameter elem_dim = 4);
   rand bit [elem_dim-1:0] a[arr_size];
   rand bit [elem_dim-1:0] b;
   // unique and repeat 3 times speciefied by the param
   constraint unique_and_repeat {
       b inside {a};
       foreach(a[i])
            a.sum() with (8'(item == a[i])) == ((a[i]%b == 0) & (a[i]/b ==1) ? repeat_n:1);
       a.sort() ;
module top_tb;
   // PARAM
   parameter repeat_n = 3;
   parameter arr_size = 10;
   parameter elem_dim = 4;
   generate_array#(repeat_n,arr_size,elem_dim) my_arr;
      my_arr = new();
      repeat(arr_size) begin
        if(my_arr.randomize()) begin
            $display(" b is %0h " , my_arr.b);
            $display(" a is %0p " , my_arr.a);
          $display("Fail in randomization");
In reply to dve12:
module abc;
class aa;
constraint s1 {
foreach(val[i]) {
val[i] < 10;
aa a1 = new();
a1.randomize();
Could you please explain what the above code is doing.
Thanks.
In reply to totochan1985:
It’s doing exactly what the original poster asked for. Can you highlight a piece of syntax that you do not understand?
I have trouble understanding these lines. What exactly ‘item’ refers to here?
What are these lines achieving exactly?
sum() is one of the array reduction methods (See section 7.12.3 Array reduction methods).
When used in a constraint, these methods get unrolled into a big expression (Section 18.5.8.2 Array reduction iterative constraints)
‘item’ is replaced with each element of the array.
becomes
int'(val[0]==val3) + int'(val[1]==val3) + int'(val[2]==val3) + ... +int'(val[9]==val3)
The cast to int is needed because otherwise the sum would be limited to 1-bit, which is the result of the equality operator.
becomes
Thanks for the response. I now understand the solution.
class A;
rand int arr,res_arr;
constraint c {
foreach (arr[i]) {
arr[i] >0; //optional for clarity
arr[i] <100; //optional for clarity
arr[0] ==arr[1];
arr[1]==arr[2];
if (i>=3 && i<=9)
arr[i]!=arr[i+1];
$display (“shuffle”);
arr.shuffle();
program main ();
A aa;
aa = new();
aa.arr= new[11];
aa.randomize();
foreach (aa.arr[i]) begin
  $display ("%0d",aa.arr[i]);
endprogram
