Write a constraint that assigns data to any address sequence that follows an arithmetic progression (ex: 1,5,9,13,17.. so a[1]=30, a[5]=30, a[9]=30 and so on))
came up with this question when thinking of how i could include arithmetic progressions in constraints.
I’m not sure if it is the right approach using randomization when generating deterministic patterns. You are restricting the RPG to do that.
The better apraoch is to write a function which generates your pattern directly.
I could say that writing data into even locations of a memory is also deterministic, which is mostly always done using constraints. My question is still valid I believe.
But there is a difference stressing a random-pattern-generator instead of using a simple function calculating your data.
Constraining to deterministic behavior has a use: say you’re in a UVM environment, and need to specify an exact pattern of stimulus. You extend the transaction class with the additional constraints, then use a factory override to deploy it. The rest of the testbench needs no changes.
typedef bit[42:0] T; // whatever you need
rand T a;
constraint progression {
   a = my_function(const'(a)); // a is a function of its previous value
function T my_function(T in);
   return in; // whatever you need to do.
