- take a dynamic array and array size should be 10.
- For 1st halfcycle the all memory locations should be zero and 2nd halfcycle the all memory locations should be one.
In reply to surya narayana Gutha:
There is nothing random about this. Why do you need a constraint? And what is a “halfcycle”?
Hi dave,
Here halfcycle means with respect to clock , In that 1st positive clock cycle I would like to print all zeros in all locations and similarly 1st negative clock cycle print 0ne’s in all locations.
I tried with distribution constraint,but some how it is not working.
Thanks & Regards,
Surya
Can you show us the code you tried as an example. SO that it is easier to see why it did not work
