Working of uvm_cmdline_processor::get_arg_matches
Hi Forum,
I notice the following code in uvm_root which looks for certain run-time args
 uvm_cmdline_processor clp;
 // Within constructor of uvm_root it's initialized
 clp = uvm_cmdline_processor::get_inst();
// Function 'm_do_config_settings() is called from uvm_root::build_phase()
function void uvm_root::m_do_config_settings();
  string args[$];
  void'(clp.get_arg_matches("/^\\+(UVM_SET_CONFIG_INT|uvm_set_config_int)=/",args));
  foreach(args[i]) begin
    m_process_config(args[i].substr(20, args[i].len()-1), 1);
  void'(clp.get_arg_matches("/^\\+(UVM_SET_CONFIG_STRING|uvm_set_config_string)=/",args));
    m_process_config(args[i].substr(23, args[i].len()-1), 0);
  void'(clp.get_arg_matches("/^\\+(UVM_SET_DEFAULT_SEQUENCE|uvm_set_default_sequence)=/", args));
    m_process_default_sequence(args[i].substr(26, args[i].len()-1));
I am not clear on the presence of prefix /^\\+ and suffix / as well as the opening and closing parenthesis within argument to get_arg_matches.
User would provide run-time arg. as +uvm_set_config_int=uvm_test_top.env,test_variable,7.
The actual run-time arg. is not prefixed with /^\\+( or suffixed with )=/ at the end.
Seeking suggestions on it
uvm_cmdline_processor::get_arg_matches uses extended regular expressions(POSIX ERE)
The enclosing "/string/" means to search the argument for a matching regular expression, whereas "string" would be looking for an argument with an entire exact match.
The ^ symbol indicates that the regular expression must be at the beginning of the argument. In SystemVerilog strings, the backslash \\ is interpreted as a single backslash \ in the actual regular expression. Additionally, the \+ character in POSIX Extended Regular Expressions (ERE) represents a literal plus sign +.
Parentheses are used to group alternatives that match expressions. For instance, (string1|string2) indicates that there must be a match of either string1 or string2. And that must be followed by a = symbol.
Thanks Dave. I am currently referring to one of the sublinks along with some additional links
( link1 , link2 , link3 , link4)
Will update this thread in case of any further queries
Could you please elaborate on the above 3 lines ?
I tried understanding it using the following example
`include "uvm_macros.svh"
import uvm_pkg::*;
  string str[$];
   if( clp.get_arg_matches("+USER_STRING=",str) ) begin:b1
     $display("+USER_STRING=%0p passed",str);
    else $display("+USER_STRING Not passed");
    str.delete();
   if( clp.get_arg_matches("/^\\+USER_STRING=/",str) ) begin:b2
Assuming run-time arg. has special characters I tried passing it as either (a) or (b)
(a) +USER_STRING=Animal#(elephant) (b) +USER_STRING=Animal\#\(elephant\)
In (a) I observe +USER_STRING='{"+USER_STRING=Animal#(elephant)"} passed for both b1 & b2
In (b) I observe +USER_STRING='{"+USER_STRING=Animal#\(elephant\)"} passed for both b1 & b2
As the display messages are same in both blocks, I don’t see advantage of using b2 over b1.
