Working of disable iff
Hi All,
For the following example ::
  bit clk , a , b , dis ;
  always #5 clk = !clk;
  `ifdef NBA
    #05; dis <= 1;  // T:5 overlaps with posedge of clock
    #10; dis <= 0;
    #05; dis <= 1;  // T:20
    #10; dis <= 0;  // T:30
  `else
    #05; dis = 1;   // T:5 overlaps with posedge of clock
    #10; dis = 0;
    #05; dis = 1;   // T:20
    #10; dis = 0;   // T:30
  `endif
  assert property( @(posedge clk) disable iff(dis) a == b  ) $display("T:%0t Pass",$time);
                                                        else $display("T:%0t Fails",$time);
   #04; a = 1 ; b = 1;
   #10; a = 0 ; b = 1;
   #10; a = 1 ; b = 0;
   #10; a = 1 ; b = 1;
   #2; $finish();
At time:5 units there is posedge of clock as well as dis is assigned 1 (either in NBA or active region)
At time:15 units there is posedge of clock as well as dis is assigned 0 (either in NBA or active region)
I am aware that the expression within disable iff is asynchronously checked,
(1) So when dis is 1 at T:5 , will the assertion be disabled OR would it evaluate ( a == b ) ?
(2) So when dis is 0 at T:15 , will the assertion be active / re-enabled and evaluate ( a == b ) ?
See discussion at
Also see
Thanks Ben.
Via both (1) & (2) assignment to ‘dis’ is done before the observed region starts at T:5 & T:15.
Hence the assertion attempt is disabled at T:5 ( as ‘dis’ is 1 ) whereas evaluation takes place at T:15 ( as ‘dis’ is 0 )
I also tried examples with the expression within disable iff being true in ::
(a) observed region ( x_edalink )
(b) reactive region ( x_edalink using +define+REACTIVE )
For (a) at 1st attempt at T:5 the expression is true in observed region,
hence the SVA is active at T:5.
There are no attempts at following posedge of clock at T:15 , 25 ,35 as the disable iff expression is true
For (b) during the 2nd attempt at T:15 the expression is true in reactive region,
hence the SVA is active at T:15.
There are no attempts at following posedge of clock at T: 25 ,35 as the disable iff expression is true
