Below is the always block which will be triggered when value of a changes .
My Question is Will always block be triggered when only strength of signal ‘a’ changes ?
Below is the snippet to support my question ?
Yes, strength is part of the value of a net. A few more lines of code in your example would have demonstrated this behavior.
wire a;
logic out, s,r='z;
assign (pull1,pull0) a = s;
assign a = r;
always@(a)begin
out = a; $display ("%t a changed %v", $time, a);
#1 s = 0;
#1 r = 0;
#1;
Hello dave,
Can you please explain how assigning the actual value to a local wire ignores strength changes and only considers value changes?
wire a, b ;
logic out, s,r='z;
assign a = r; assign b = a;
always@ (b) begin
out = a; $display (“%t a changed %v”, $time, a);
