I go through the LRM and still do not understand exactly why we say “$urandom has a better random-stability than $random” while both of the two functions can generate random values according to the “seed” argument
In reply to jianfeng.he:
Actually, in our code most of the time, we deal with positive integers.
$random might get you a negative number. But $urandom won’t because it’s unsigned.
That’s why we prefer $urandom.
In reply to Shubhabrata:
This is really a difference between $random and $urandom, but I guess there are some other differences in random-stability, I did a little test and found that $random did not affect the random results of subsequent codes, I want to know why, thanks!
Yes, the main reason not to use $random is it does not have the random stability properties of $urandom, randomize() and other SystemVerilog randomization constructs. You must manually control the seeding.
Another problem with $random is its distribution is not uniform across every bit. It uses a very old and simple randomization algorithm that is prescribed by the LRM.
And finally, the seeding of $random and all SystemVerilog randomization constructs can be controlled by the command line to run different seeds without having to modify your code.
BTW, how to control the seeding manually in a process? I can only get the string of rand state of current process by calling get_randstate() function, however the “seed” argument of $random/$urandom is int.
