Hi Experts,
For uvm_blocking_put_port#(T) the export is uvm_blocking_put_imp#(T)
Similarly for uvm_blocking_get_port the export is uvm_blocking_get_imp#(T)
But for the
uvm_analysis_port
we have
Why we have 2 implementation port ?
Regards,
Georgean
There is a difference between uvm_analysis_export and uvm_analysis_imp.
uvm_analysis_imp is the actual implementation port, which calls the write function of the component which instantiates it.
uvm_analysis_export is used to export the port connection to all its connected implementations and subsequently to their instantiating component’s write functions. i.e., the write function of uvm_analysis_export calls the write functions of all the connected interfaces (which can be exports / imp’s), whereas the write function of uvm_analysis_imp calls the write function in component.
With reference to the uvm_blocking_put/get_port, in addition to uvm_blocking_put/get_imp, there is also uvm_blocking_put/get_export. And these exports are to be ultimately terminated in an implementation port, which calls its instantiating component’s put/get() tasks.
Long answer short, there are exports and implementation ports for blocking_put/get_port, similarly, there are exports and implementation ports for analysis_port as well.
-Sailaja.
