Why UVM allows connecting multiple exports/imps to a single put port
Why UVM would allow connecting multiple exports/imps(uvm_blocking_put_imp) to a single put port(uvm_blocking_put_port) (because it only writes to a single put implementation)?
function new (string name,
uvm_component parent,
int min_size=2,
int max_size=2)
Because UVM allows setting min_size to 2, Expectation was it will write to both the put implementations(if two are connected). But it’s not happening.
I understand analysis port should be used for such scenarios but in that case the new method should have been restricted for the same.
Prasad
I also want to know why.
